Passanger side ABS sensor
Mine seems to have torn in half almost, at the bit where it plugs into the hub, so was wondering:
- are they easy to replace?
- expensive?
- does anyone have a part number, or know anywhere other than Renault that will sell them
Cheers in advance!
if uv not done it already then here u go...
just done mine 2day m8, £56 from Renault for the loom. peace of piss to fit.
One locking screw to come of hub from top of the sensor just behind the disc then it SHOULD pull out.
Mine was stuck in and had to brake it and hammer and punch it out in the end but wasnt hard.
make sure wen u fit the new one that the sensor gose it without a fight.
If the hole is to tight then drill it out/clean it up and wak sum grease in there.
Should go oin alright after u hv done tht tho.
Wat ever u do dont bash the new sensor in ie hit with a hammer. you will bust it!!
