Passenger Airbag Disable Resistance?
Car  Vauxhall Corsa
I want to remove the key activated passenger airbag switch from on the passenger door. What value resistor do I need to replace it with to recreate the ‘off’ position?
I whipped it out completely and it throws up an error code.
I'm sure you could check with a multimeter what ohms resistance you need.
I assume you have removed it to remove the door cards for track? Can you not pug it back in again and cable tie/fix it in place.
