Hi everyone,
I've tried searching for the solution to this problem but no-one has been able to come up with a definitive answer.
Last night it was chucking it down and in the hurry to get inside away from the wetness, I accidentally pressed the central locking button when the passenger door was still open.
Now, the drivers door and the boot will lock with the central locking but the passenger door can only be locked manually with the lock.
I've tried disconnecting the battery but that didn't do anything.
My passenger door lock used to make a whirring noise when the lock was used but now that doesn't happen so I can only assume that there is no power going to the motor or the motor has packed in (which is a bit rubbish considering all I did was lock the door when it was open!)
Anyone make any suggestions? I'm thinking a new motor by the sound of it. I would check the connections but I'm not sure how to.
Thanks everyone
Thanks everyone
