Passenger door slight drop
Car  Mec 350 slk manual
HI
When I close the passenger door I have noticed it has a slight drop and have to lift it a bit to close it could it be the door pins worn ?
Means the pivot welding on your door hinge is about to break, i had this on mine, either jack door up and have it welded but may not be 100% so i went with a door fully off job and re welded
normally means ex user was a bit of a swinger on the door (typical of a gf like mine haha)
Thanks elliot182
i will take the car to a body shop and have it checked out and get it done
On mine i noticed a little chip of paint where the top corner of the door wasnt fitting correctly
The door fits ok it's just when you close you have to lift slightly I was thinking door pins or trying to adjust it if you can ?
