Passenger window problem.
Car  Titanium 182
Window goes down fine, on the way up after about 2/3 of the way up it makes a squeaking noise and slows right down. (Still goes up)
Its like something in pressing on it inside the door. How do I get the door card off, it appears to be glued on :S
(172 ph1)
Appreciate any help
Ta.
could be the runner dry, squirt a bit of oil or wd-40 into the rubber and try that first
remove all torq screws and rip ot off, its stuck on with some nasty black s**t
Are the runners are certain positions behind the door card ? or should I just spray wd-40 along the entire inside of the window seal ?
You might be able to help me !
I've just been to Renault today to buy some replacement torx screws (The ones at the bottom of the door, think there is 4 on each door)
Can you find me the part number :o my parts guy couldn't find it and I'm 4 screws down !
