Pc issue
Ffs.
Turned computer off. Turned it back on and now nothing is coming up on monitor, tried different monitor.
WTF any sugestions?
  Turbo'd MX-5 MK4
Is it beeping when first switched on? If so, the sequence of beeps will lead you to a fault code.
  clio
I assume you plugged the power on the monitor in? lol
did you use the same power lead to connect the other monitor?
Check fuses / try different plug sockets.
if not these and you're sure the monitor works - remove and reseat the graphics card.
if this doesn't work new graphics card.
  Turbo'd MX-5 MK4
if the graphics card had failed in anyway you'd expect beeps from the motherboard, so it does suggest that its something to do with the monitor video/power cable or fuse)
  Turbo'd MX-5 MK4
any failure with the computer itself should cause the motherboard to beep, if its not beeping at all it does suggest the computer itself is fine.
  Turbo'd MX-5 MK4
how old is the PC? its strange it is not beeping at all.
I'd try taking the graphics card out (unless its onboard) and reseating, although as said you should be hearing beeps if its at fault.
4 years.
Taken ggraphics out and memory. Given it the old blow trick then tried on different monitor. Hmm.
Could try different memory/ graphics card?
Not monitor for sure, just use the monitor on different pc. Nor is it gfx card, just used different one. Tried different ram too. Nothing.
  Turbo'd MX-5 MK4
didn't expect it to work, as said if the computer was unhappy about any of the components it should beep. Can you hear the HDDs spinning up and being accessed?
  Turbo'd MX-5 MK4
tried removing the BIOS battery, powering on/off, replacing the battery and powering on? (or just clearing the BIOS with the jumper if it has one/you know where it is?)
  Turbo'd MX-5 MK4
it looks like a watch battery on the main board (motherboard) itself. You should be able to lever it out, turn the PC on, leave it a while, then turn off. Replace the battery and power back on, that'll clear the BIOS and return it to its default settings, may resolve the unknown issue. (Its worth a try anyway)
Does the PC have an internal speaker on the case? Is it connected to the motherboard?
  Turbo'd MX-5 MK4
tried changing the memory? I'd strip it down as much as you can, i.e change the graphics card, change the memory (only use one DIMM) remove any other cards, disconnect CD/HDDs etc
Memory and graphics are fine, booted another computer with them. Only have 1hd plugged into mboard, nothing else...
  Turbo'd MX-5 MK4
I'd say the motherboard itself has gone. When it was working it should have been giving a single beep to say it was ok, now its not beeping AT ALL suggests its a fundamental problem with the motherboard.
I've got a psu that will work. I've broken it down now. Will rebuild it later with different parts bar the motherboard to see. What a pitta. Not what i need.
