PC/Laptop Hard Drive - CHKDSK
Car  BMW F21 125d
When running a chkdsk I am running errors.
For Eg...
Attribute Record (128, "") from file record segment 96204 is corrupt.
Ending With...
Errors Found. CHKDSK cannot continue in read-only mode.
Now.... I ran cmd prompt as an administrator.
Is the only way to resolve this a format and laptop rebuild?
All help appreciated.
chkdsk /f
That should give you the option to run chkdsk next time you start the PC (I.E before it reaches Windows). The read only message appears because you are running chkdsk within Windows.
Ok i've scheduled it to run at next reload.
But the errors I am seeing, corrupt file etc, is there a way of getting round them without a rebuild?
Griff you are a legend.
chkdsk /f fixed the errors and now all is looking good again.
C:\Windows\system32>cd/
C:\>chkdsk
The type of the file system is NTFS.
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
133184 file records processed.
File verification completed.
570 large file records processed.
0 bad file records processed.
0 EA records processed.
60 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 3)...
176470 index entries processed.
Index verification completed.
0 unindexed files processed.
CHKDSK is verifying security descriptors (stage 3 of 3)...
133184 security descriptors processed.
Security descriptor verification completed.
21644 data files processed.
CHKDSK is verifying Usn Journal...
37264120 USN bytes processed.
Usn Journal verification completed.
Windows has checked the file system and found no problems.
309371737 KB total disk space.
86799804 KB in 108161 files.
62592 KB in 21645 indexes.
0 KB in bad sectors.
249497 KB in use by the system.
65536 KB occupied by the log file.
222259844 KB available on disk.
4096 bytes in each allocation unit.
77342934 total allocation units on disk.
55564961 allocation units available on disk.
C:\>
