Ph1 172 interior lights - something missing
Car  172 Ph1/Scooby MY00
One of the bulbs in the window switch has stopped working. I've hit it and it still won't work :approve:
So I'm wondering 1. what type of bulb is it? and 2. What other bulbs aren't working any longer - is there supposed to be a light in the ashtray (it looks like there should), is there a light in the wing mirror switch and is there a light in the glove box?
If someone knows can they tell me.
the window switch.
Mine broke at about 70k miles. i took the door card off to fit speakers and once i replaced it and plugged it back in, it worked again.
I assume after 70k of pushing it the plug on the back just worked its way loose. So give that a try.:o
Cheers. I'll try that. Door cards came off recently to fix a noisy electric window mechanism so might be the cause.
There is one in the ashtray. The connector comes loose. Pull the ashtray out and have a fiddle with the cig lighter connector as I think they use the same light.
Theres no light in the glove-box and the bulb in the interior light is a w5w.
Thanks M8.
