PH1 172 TDC Sensor - How to get at it
  2001 X Reg 172 PH1
Hi , changed my spark plugs but still have intermittent starting .
How do i get at the TDC sensor on a PH1 172 ? Ive heard its on the left hand side of th engine bay but where ? do i need to remove anything to get at it ?or go from underneath ?
Ive looked through the forums and people are finding it dead simple to clean/ replace ? But im not ?
Cheers for any help
  Megane dci 130
Pretty simple but not the easiesy engine to do it on. Remove the airbox and it will be on top of the gearbox under a few coolant hoses. Make sure you replace the sensor with the peice of modified loom also.
  330i. E30 Touring.
As stated, where the gearbox bellhousing meets the engine block, at the top.
Remove airbox.
It's held on by two 10mm bolts.
