ph1 172 Throttle Cable
richard691
Car  Twingo RS133 & 172
Can someone post a photo of where the throttle cable goes through the bulkhead on a ph1 172?
Richard
it's just under the servo. easiest access is through the wheel arch. pop the arch liner and you'll find a bung where the cable goes
When you pullthe archlibet off of te drivers side there is no other cable there in the position of the accelerator cable mate uncoil the pedaland push it through the bulkhead and you will know where to pull. Have you read the guide on here
I've got a mk2 which doesn't have a cable as standard. Reason I'm asking is because I'm converting it rom FBW.
