Martin_172
My ph1 172 has developed a starting issue.
When I put the key in turn it on, everything lights up as it should, immobiliser light goes out as it should, turn it to start and nothing happens, not even a click like you get with a flat battery or dodgy earth.
I've confirmed the battery is good, Earth strap is good. I'm going to get it into work to get it on a ramp and ill check the wiring to and remove and test the starter if required but just looking for any other suggestions while I have it there before I go down a rabbit hole!
Oddly enough one time since it started faulting, I turned the key and it jumped straight into life, let it ran for a few minutes, turned it off and tried again, same fault!
