What's the common fault (is there a common fault) on ph1 front fog lights? I've checked the bulbs and they're fine. I've also replaced the wiring matrix that runs behind the front bumper and still can't get them to work. Rear fog works fine.
Heres what I did to sort mine. Neither of them were working so asked mate of mine for advice. Ended up using a couple of fine model making drills that can be used in your hand and very carefully turning them inside all the wiring sockets that the pins go into on the connectors then soaked everything in WD40 and put it all back together. They both work now. The connectors get verdi-gris in them over the years and stops everything working.
It takes a little bit of time to do but if done properly well worth the effort.
