only early ones had return lines. Later single line systems have the regulator in the tank attached to the pump. Neither is better really, both supply the correct fuel. for a turbo'd car IMO a return line setup with regulator up front is better as you can have vacuum/boost compansation on the regulator, but otherwise it makes no odds
