Ph1 has slightly taller gearing i think around 5% off the top of my head.
Also the ph1 has a speedo sensor in the gearbox but the phase 2 takes the speedo reading elsewhere i believe
You shouldnt have any problem tbh if you want to put a ph1 box in a ph2 as the car will pick up the speedo from the abs anyway, it would just be marginally slower due to the gearing.
Its if you put a ph2 box in a ph1 you have to work out how to get the speedo working (unless you use a cup box which has the speedo sensor also)
I think anyway!
Hope that makes sense fella
