My clio has started to cut out when cold. It will drive okay, but just won't idle until slightly warm.
Although I have noticed if I turn the ignition on till the lights go out (20-30 seconds) before starting it mostly seems okay.
I was thinking idle control valve, but not sure if this would only cause an issue when cold. Otherwise maybe something to do with the fuel pump/injectors?
No fault code are showing (admittedly its a cheap handheld reader)
