PH1 Instrument Cluster wiring the same as PH2 172?
Car  Clio 16v 'YOJ'
Mainly looking at the actual 172 PH1 and PH2 instrument cluster plugs.
I am looking to wire in my ph1 instrument cluster into my mk1 - are the plugs the same for the ph1 and the ph2 as I have access to some ph2 plugs but not ph1.
I believe the ph1 has a 30 pin grey connector and a 15 pin red connector, what does the ph2 have?
Hi thanks for your reply - I can confirm the plugs are the same - unsure about the wiring but that doesn't matter as I will be soldering the plug into my mk1 loom anyway
Thank you :)
I don't suppose you have a pin out for them do you? A friend of mine wants to put the matching ph2 dials from his engine into his car (mines ph1 clocks and I already have the pinout for that one) thanks mate
You have the phase 1 pinout? Please share!
This is what I have but so far it's not matched either the Ph1 or Ph2 dials I've used.
