Schma Schme 1.6l
since changing the timing belts my 172 has start to idle a bit odd, it often stalls because the revs drop so low. however, it revs fine and runs perfect throughout the rev range. when we did the belts, i removed the throttle body and gave it a clean out with some carb spray cleaner.
i had it put onto a dianostic thingy by a friend and he cleared a few fault codes, nothing related to issue though. BUT he did say his first thoughts would be to look at the throttle postion sensor?
there is also what sounds like a minor air leak, but i'm not sure as i wouldn't know how/where a vacum is on a clio.
anyone had something along the same lines?
