Ph2 Rear lights problem
Car  172
Ok so I connect up my ph2 lights to my ph1. I have wired them up properly following the guide etc..
My problem is that my drivers side rear light wont light up when you I put the lights on, but the same bulb DOES light up when i brake..
Might be a simple fix but I've got no idea why its doing that so any advice would be helpful
Tom
They can't be wired up properly surely? Have you tried swopping left and right lights over to see if the problem is the wiring or the light cluster?
