Pretty sure they are the same. Its an easy change.
2 x 10 or 13mm bolts holding the rail cover on. Take that off. Soak with WD where the injectors go into the inlet. Unplug all injectors. Squeeze and pull fuel line off the rail. Two 10mm bolts holding rail to inlet. Pull and wiggle. Can be a bit of a pain, but pull hard. Rail should pop out.
Then just prize injectors off the rail by the clips
