Phase 1 double barrel cat (am i restricted to using just this cat)
  Mk5 golf gti
as above, my cat is fubared
is the double barrel cat the only one i can replace it with
i have mot due within next couple of weeks so i need to replace it
thanks
  330i. E30 Touring.
Ph2 cats are a different length, fyi.
Also, make sure you get one with the correct. Amount of lambdas. Either single of double lambda.
  Mk5 golf gti
Yes but isnt there 2 different types of cats for the phase 1
older models had the twin and newer had single??
i know the ph2 wont fit
  ITB'd MK1
right, all ph1's had the twin cat, but very early ones had only 1 lambda sensor. If you have a post cat lambda sensor, then you can use a ph2 cat
  BMW M135i
You can still use a Ph2 cut just blank the second lambda hole. BUT you'll have to change the exhaust too so no good really.
  2004 ph2 172
For those who've never seen a "Double Cat" .. here's mine next to the K-tech Decat pipe.
