Phase 1 speedo to run off abs sensor, how ?
Been told it's possible so I can fit a later gearbox but can't find anyone who has done it or if they have done a thread about it
Anyone here done the conversion ?
The gearbox will fit on, but as far as im aware there is no way of running the dash off the abs sensor, unless you run an aftermarket dash, then a speedo pick up off the driveshaft would be easy.
Bear in mind if you get a 172 cup gearbox, they use speedo drive, and have different ratios to the Ph1's
