Pic request, Headlight sensor
  Dodgy one
as above, I have Xenons and went over to whitby last night and couldnt see no further than 10yds in front of me :eek: Could someone post me a picture of the sensor on the beam which senses adjustment for the lights, ive had a look but cant see anything and dont know where it should be located.
  Dodgy one
Is there not a grey sensor / sticky out bit on the beam? i didnt want to adjust the adjusters if i could help it
There is a switch on the rear beam. It's on the passenger side from memory, quite obvious to spot.
They fail quite often. Shouldn't really need to adjust them on the back of the headlights, as the switch on the rear beam does it unless it has failed, in which case you'll need to fit a new one.
