piper cams
  182 inside
After much reading and discussion with people who have piper cams fitted. I've decided to get them. As I'm doing my cambelt and aux belt end of the month. They need my cams for 5 days at £283.00 so not to bad.
List of thing s happening to my beloved 172 are: New rear discs and pads, inlet matching/porting, Rear carpet fitting as I've removed seats etc, Eibach sportlines and camber setup, Cambelt and pulleys, Aux belt and pulleys and finally Piper cams.
I hope to see a large increase in torque and GO! If not then it will be off for remapping at RStuning.
;) lots of ££££££
  Clio 182
if your getting uprated cams then you will need a remap. Otherwise you are waisting your money. Why not add a panel replacement filter to your list? only 40 notes.
