Playstation headset...
The_Pirate
  Golf R
Morning guys, quick one about the PS3 head set/bluetooth ear piece -
I sync'd it with the Playstation and it says its connected but i still cannot get it to work? Its fully charged and the green lights blinking but alas still nothing?
If other users have a head set, should i be able to hear them through that or can you only hear them through the TV? Im not great with these things but is there something else i have to connect to to make it work?
Had a wee scout through google but not turned anything up?!?
Any help appreciated as usual! :cool:
  Clio 1.2 16v
as Treemanx said
follow this guide mate, i think you have already done the first bit so just do the second part
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.​
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.​
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 3. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.​
  Clio 1.2 16v
Thanks alot mate! Very helpful! Sorted now and ready to verbally abuse americans! lol
no problem man! what you playing online on? add your ps3 gamer tag to your profile and il send you a friend request or just add me its dredz08,
p.s when you can afford it upgrade to a set of stereo headphones like turtle beach px21's i got mine yesterday and there sooo much better
Aly you've scared him lol if things carry on like this at work i should be on mw2 by about 8ish
it would take more than that to scare that boy off, he loves being called a **** tbqfh!
i should be on later dredz, just hope your connection is better as that game
