Port size
Car  Clio 220 lpg
Hi just wondering what size is the port on a standard 172 at it's smallest after the split? had a engine developed from a standard a 140 head and I'm starting to think it may be to small, mine is 24.3mm at the narrowist part.
oh i see. Do you mean you started with a non CNC'd port megane coupe F4R head then? I dont have measurements, but i'd expect a significant difference having seen both
Std is 25mm diam, so mcsa is 982mm^2 for the whole port.
Theoretical calcs would say thats sufficient for about 195bhp (mcsa alone, not considering transition/turbulence/velocity etc).
