power cables
in my mk1 clio what thes best way of running power cables through the bulkhead to the battery? and once inside the car which side should i run them? cheers
Right on my 1995 rsi i ran the power cable through a rubber grommet in engine bay, had 2 cut in2 it 2 get it through, was a bit of a pain, its at top of passenger footwell area if that helps, then ive run the power cable down left side of the car, under the skirting
