Power-flex top mount
Car  172 cup
I've recently bought a top mount (172 cup) which looks like it just sits with the original mount. They look fairly straight forward to change, but are they? Any special way or things I need to watch out for?
Had a search but not found my answer.
@bloke did mine with others jobs.
But at a good guess remove mount, place insert in, put mount in, done.
Just make sure the mount looks OK to use
Oh hang on. Where is the mount?
You'll need to support the engine with a jack, stick a piece of wood on the jack to be safe and you shouldn't have any problems.
Did it yesterday, took like 4 minutes.
Support weight of engine with a jack with a bit of wood under the sump.
Undo three bolts and the nut in the mount.
Take the OEM insert out, place Poweflex one in, place OEM insert in that and then do it all back up.
If you buy the insert new it comes with instructions anyways!
