power steering fluid leak
hi chaps, im having a problem with the power steering fluid leaking from the feed pipe to the pump on my valver. ive replaced the pipe two weeks ago but it has gone again. its as though pressure is building up and therefore blowing the rubber seal in the joint. has anyone come across this before or at all know what the problem could be? many thanks, scott
cheers matty. ill give it a whirl. it seems to get worse sometimes. it pisses out as quick as put more fluid in. is it possible that there could be some sort of pressure build up or something?
