POWER
got a couple of neons, cathodes, lights etc, but dont want to power them off the ugly cig lighter plugs. where can i plumb the wires in so i can power them off summat, that will power them constantly, (unlike my glovebox one which only comes on when opened)
i wanna put some in the footwells, and some in the rear footwells. where can i power these from??? HELP!!!
I think the best option there would be to put a direct feed to the battery with a suitable switch or switches in the car so that you can turn them on from inside whenever you like.
Russ
i wired up some under car neons to my clio, what i did was u know the dial for moving your headlights up and down well use the 12v off that, im guessing yours is a new clio like mine, the lights are automatic so whenevr it is dark they will come on with your lights, after that i wired a switch into that big blank plastic pannel next to the headlight adjuster so that if PC plod is passing you can switch em off dead quick.
Hope that hekps u mate.
Rich.
oh, how does a clio ride when its lowered. im considering doing it but i dont want it to ride like a go kart and feel every bump going!!
ah, but smething tells me thats not true
fred has the lowest clio which is -100mm all round on 17s and even that is too low
