Powerflex bushes
Car  Clio 172
I have a 51reg 172 and im looking for Front Anti Roll Bar bushes.
Does anyone know what the outer mount is? 22mm or 23mm?
23 for sure. 23outer/25 inner are for the 182, I know because I have the complete set :)
they do. you'll probably never have to change them :D
don't listen to "they'll make the ride harsher" crap, I didn't feel anything harsh with mine
I also had the lower arm bushes at one time, nothing harsh there as well
correct. you have to weld the lower arm outer sleeves to the arms:
or else they will come off and rub on the subframe mounting brackets. been there, done that..
I did it this way and it worked fine. others welded all around the sleeve. I think care is needed when doing so, i'm not sure about the polyurethane's resistance to heat. mind you that I had the sleeves spot welded on both sides so it should work just fine
