clio 172
Ive had my lower wishbone sleeves tak welded and the bushes fiited but when ive come to fit them to the car there no where nere the righ position to line up with the subframe mounts.
It looks to me tha the sleeve has not been welded further enough along as the bush it about 5mm away from the inside of the arm on both sides and on some pictures i have seen here the bush is probably less than 1mm away from the inside of the arm.
any advise mesurements ?
I will have to give them back to steve to re-do if there wrong.
will go take another look at them now though
