Scirocco GT 2.0
Rather not have to stick one of them pads on the back of everything I want to charge tbh.
How the hell does it work, so the power mat sends the charging power to the battery inside the phone???
"You have two coils, the Primary Coil and the Secondary Coil. The Primary Coil is connected to the Power Outlet. When this happens, a magnetic field is produced around the Primary Coil. Now, depending on how many Turns there are in the Secondary Coil, the output voltage is higher when there is more Turns, and less when there are less Turns. Now, using the standard UK Voltage, 230v, as the Input. Let's say there is 10 Turns on the Primary Coil. Now, we need something like 9V to charge up the devices. That would mean we would have around 25-26 Turns on the Secondary Coil to achieve this. If you're wondering where the Coils are, you would have the Primary Coil located inside the Power Mat itself, where as the Secondary Coil would be located on the small device that you attach to your device (iPod, Mobile Phone etc.) Thus, wireless charging is achievable."
that sounds like blocks to me as you'd have less coils on the secondary to have a lower voltage
Whats the benefit over just dropping your iPhone into a dock?
