Pre cat lambda location 1.4 16v
Yes and no... its not hard but you'll need to remove the upper heat shielding and to do that you're gonna have to remove a lot of the inlet plenum, faff about with some 10mm bolts that will most likely be corroded then you're going to need an HO2 socket to remove it as you're not gonna get a 21mm spanner in there.
Mick
