Pressure washer help
  190 BHP Willy 2
Bought a karcher K297 pressure washer with vario lance today from argos. All's good with the hose connected to it BUT................... I've read so much about running it from a large container with soap in to leave "snow" all over the car. Tried this today with disasterous results. its fine for 5 secs then loses all pressure.
I'm dropping a 2 metre length of hosepipe from pressure washer into a 25 litre container of megs wash (i like it as it gives loads of bubbles but contains no wax) and it just doesnt work. Where am i going wrong?????
Scott
Tay
  Titanium Clio 182
Make sure that your pump type on that model doesnt require a minimum "in" or feed pressure from the water line going into unit.
i.e it sucks as well as blows oooohh errrr !!!:eek:
This is where my pressure washer let me down as I tried the same 25ltr drum foam trick (Great idea by MrBilly i believe) but would not run without a min feed pressure of 1.5bar i.e. tap water feed.
Was most annoyed !!!!:mad:
Check your destrucions matey ?;)
  190 BHP Willy 2
Prob like you said mate, needs more pressure.
I've ordered a gilmour now :approve: Could of bought attachment for karcher but sod it.
