Problem fitting new throttle pedal
danward
Car  M135i
Hi guys,
I bought a metal throttle pedal from a member off here to replace the one I had which was rubber. I bought the whole unit so I could just unbolt the three bolts holding the unit on, swap them over and off we go.
Problem I have is that I've installed the new throttle pedal, plugged it in, and when the car is started up the revs are holding at 2k and the pedal itself when pressed is doing nothing what so ever.
What have I done wrong here? Or is it a case of needing a garage to install this?
Ah!! Not to worry peeps. I've sorted it now - turns out I hadn't plugged it in properly.
Funny how you can miss something so simple haha.
