Problems changing foglight bulb in valver
  MK1 Clio 16v
I've just tried to change the bulb in one of my fog lights in my valver.
I managed to get one screw undone but it was VERY tight, but the other screw was even tighter and eventually it gave way, now it's all chewed up and i can't unscrew it.
Does anyone have any suggestions on how i can get it out?
Thanks.. :eek:
  MK1 Clio 16v
How do you 'drill it out'?
Just use a small drill, and drill through the middle of the screw to make it turn?
Da
  Less
drill into the middle of the screw head to separate it from the screw 'stem'. then take the cover off and remove the remains of the screw with pliers or similar.
  MK1 Clio 16v
I'm not sure if that's possible as the screws are recessed into a plastic surround?
I'll see what i can do with it on Saturday, and i'm going to order some new fogs from K-TEC Racing as mine are beginning to rust on the inside..
