First off my car was wired from bulkhead inside the cabin I had to create the wiring loom from the bulkhead connector R107 to the ECU.
I have the D4F 712 variant with the ECU mounted to the rear of the block/rocker cover.
After a session programming the dials (they are PH3 so they're digital) I've got the limiter to activate with ignition on and SET ---- is visible
Yet once the switch is changed to CC no green light emits and clip doesn't see the status mode activate but limiter mode is visible.
Neither of the steering controls for CC are seen, I'm unsure if this is anything to do with me not enabling anything on the ECU to do with CC/Limiter
I've belled the wires from my loom into the cabin and they're fine I've also fitted the clutch switch.
I'm having fun browsing the French Clio forums for similar issue to see if they've resolved it.
Now it could be I need to enable CC in the ECU, to which CONFIGURATION is greyed out or my clutch may not be earthing too thus not enabling CC to activate.
AlexW GrahamS
AlexW GrahamS
