good work. did you use the thermal grease with the zalman or artic silver 5? good temps?
also, did you attach the optional asus northbridge cooling fan included on the mobo??
I used AS5. Sitting in the BIOS, the CPU temp was idling at 55c, which I thought was a bit high really, but it'll likely cool down once it's all cooked in. Something I'll be monitoring for sure.
No I didn't use the additional cooler. It may be an option when I start OCing, but frankly the Zalman is massive - 110mm fan blowing straight over heatpipe fins anyway, so not necessary IMO
Vista 64bit is installing as I type![]()
You may not have the heatsink seated properly they are really sensitive to it on the intel cpu's. Also possibility of un even surface on heatsink / CPU causing higher temps take the heatsink off again and have a look if the AS5 is grouped in 1 area chances are it was badly seated might have to do it a few times until you get it right. Temps should be way under that though.
If the board is reported 55c it is likely up around 60 - 65c can find this out using coretemp. But with vista 64bit you will have to turn off the driver validation to use coretemp which you do by pressing F8 on bootup to bring up the other menu. coretemp will give you the true heat output as it reads the internal sensors in the CPU for each core.
