Puddle in spare wheel compartment in Boot
Car  99 clio 1.2 dynamique
Hey there,
Just went into my boot there to get the spare tyre and notice that the well where the tyre is kept have a large puddle of water init. Checked if anything was leaking but nothing is. Also nothing in the boot is wet either. There must be a leak somewhere. Does anyone have any ideas where it could be coming from?
from below ? There's the pin that holds the wheel and maybe this is loose so water can enter there ?
... water should also drain from there then if that's the case ,so might be wrong...
Cheers. Found out the the boot seal was duffed. Just took it off and plastered some silicon round and put it back on. No more leaks! Woohoo!
