Pulling Left and right quite vigorously not when brakeing
Car  Clio Sport 2.0 182
hi ive just brought my 182 and when im driving it wants to go right mostly depending on the road surface to the left as well if i let go of the wheel it goes leftor right and turns the car in tha direction very sharply not a slow turn a fast turn since i noticed tis ive taken it to a garage and had
new front spring due to one was snaped
tracking twice
correct tyre pressure
there is a slight vibration when braking some times i have noticed but it turns when not braking so i dont know if it could be the brakes i very concerned about it if any one could suggest any think i would be ery gratefull and will keep posting my progress
just taken it into a renault specialist they had a long look at it and they said they couldent find the problem they test drove it and said it was a drangerous problem. i have had it tracked twice already but they told me there was no sign of it being tracked at all so i have re-booked it to be tracked. also if it does not solve the problem the wishbone bush seems to be out on the drivers side front wheel so the wheel sits closer to the arch than the other side but they said it wouldent cause it to steer of that seriously but could be adding to the steering problem if the tracking is out
Warped discs would cause vibration, perhaps combined with binding pads. Might also cause the car to lurch when turning.
Suspension-wise, could be anything really; from worn bushes to bent wishbones and anything either side or in between.
Just brainstorming.
just had it back from a renult specialist they suspect both drivers side wheels have hit the crub at speed at some point no alloy damage to see but might of replaced they said its not one big thing causeing the problem tsa few small things makeing it a problem i need a
complete rear axle (slightly bent)
drivers side front hub
drivers side front shock
drivers side front wishboe
four new tyres
got quoted minus the tyres £400 for the job includeing laybour and vat which i think is very good if any one knows of some good tyres toyo for a good price please let me know got quoted £270 for four or 45 for buget tyres might just go for the buget i having it dne soon so if it all works out i will be very happy
Sorry to hear mate, abit of bad luck there. My new one feels abit odd upto my last one although I think it's because I'm used to lowered ones. Hoping it's just a worn bush or two.
Good luck with yours buddy :)
Don't buy budget tyres. I've read good things about Hankook V12s if you can't stretch to something like Michelins
