Pulsing lights on idle
JezzaMac
Noticed recently that all my lights are pulsing on idle including the window motors also pulsing when putting the window up. Everything stops pulsing when about 2k rpm is reached.
Is this likely to just be the alternator needing replaced or is there anything to check/clean/replace first?
Hey jamie. It certainly sounds like a earth issue. Have u tried the windows with the ign on but not started?
As above jamie, Check the earth straps and clean them up with some emery paper to see if that helps.
If not check the alternator
