182cup & 172 racecar
Yes, locktite them in.
Just fitted some. Not used in anger but seem very good. If you're not using spacers you'll need a long socket. I bought a nylon covered one from Halfords.
Yes true and PM say that on their too.Remember if doing that its the blue 17mm one you need not the green 19mm one like on a normal clio bolt.
I'm the same tbf I leave it on stands overnight before fitting the wheelsBest to leave the car on stands for a while for the stud lock to set, that's my ocd there though.
It is REALLY simple.
Remove wheel.
Put some stud lock on the thread of a stud (the bit going into the hub behind the shoulder).
Wind it in using allen key.
Repeat 3 more times for the other studs.
Put wheel on, do nuts up.
Then same on the other 3 wheels.
