purge valve help
ADS_V6
Car  172 cup clio v6 st
hi can the purge valve cause poor running,can i just disconnect it will it cause any problems thanks
Hi got fault code active bi mode air inlet solenoid valve on machine,been told its the purge valve have i been misinformed Dan thanks
agh ok the thing under passenger wheel arch i can ignore that code then,that wont effect car will it
