Putting In Bucket Seats
Rite im gonna buy a set of seats for the front when i take out the old ones will the airbag lights always stay on?? How Can I Pass This??
  Punto/Clio GTT
does it? hmmm, get an aftermarket steering wheel then... de-airbag the whole car, all they do is break your nose anyway :S
Has
  RS 182 - Black Gold
^^^ Make sure u tell the insurance company !!!
Not a good idea just to rip them out, if u have an accidetn and insurance finds ur airbags removed without delcaration u WILL be screwed!!
Stick a correct sized resister in the wiring for the airbags and the light will not come on.
I think the stearing wheel is 4.6 ohms and the side is any value between 1.8 and 6.5 (or 4.5) ohms.
Ill do a check though.
ok where abouts do u put the resistor then??
connect the resister between the two wires that cinnect to the pre tensioner, gives the ecu the impression thepre tensions are connected
  Golf GTD
Quote: Originally posted by blackclio on 04 January 2005
yeh but when the lights are on that means that none of the air bags work!
u know that the side airbags are actually in the seats? the other 2 should still work though.
Ok you have a problem with your car since you set the airbags off youll have to make a choice.
1) Replace the airbag computer then either replace the airbags set off or stick resisters in the setup.
2) Remove the bulb/ wire from the dashboard (Its track ten on the grey connector)
Theres no other way of getting rid of the light. The airbag computer is a waste of time now to get the other airbags to work you need to replace the unit get Renault to set it up and either stick a new airbag in or resister up the wiring.
