I've got a blackline and its brilliant, seems to be handling the extra power too.
Never heard of having to flush the gearbox oil though, where did you hear this @Matt Cup ?
I used Fuchs Sintofluid as suggested by @NorthloopCupCan you use regular Elf NFX oil with an LSD or do you need to use something more specific?
Just go for redline MTL 75-90 GL4Can you use regular Elf NFX oil with an LSD or do you need to use something more specific?
This is what I have, hence a little gutted to flush it out but needs must.Just go for redline MTL 75-90 GL4
It's levels ahead
If you can get it, it was NA when I was looking!Just go for redline MTL 75-90 GL4
It's levels ahead
I think they renamed itActually, im using the MT90, not sure what difference that makes other than it seems to be more expensive.
I usually go to Opie or I found Fuzz Townsend's Classic oils for itOpie usually have a good stock of MTL and MT-90.
Genuine or SachsWhat brand of clutch would be recommended?
Paddle Clutch only, the Organic plate has issues and sticks above 6500 rpm. (well mine and others did) I have a full sachs organic clutch kit with a few thousand miles on. £600 of junk.Sachs performance if it’s being tracked
