Question: 16v disks and calipers ona RT
i gotya, need to know if they are the same, a friend has a set of gtt calipers and discs, just need to know if they are the same as the 16v,
and what sort of improvement should i expect from the 16v/grr set up as opposed to my rt ones?
dont be expecting more braking power... only less fatigue caused by the braking heat.
heard that some ppl had problems using this upgrade... too much pedal travel? Mine is the same as previous.
ive got huge pedal travel as it is
was hoping for added braking power as the brakes are hardly worth having at the moment lol
lo mate,
yes the willy/16V/GTT 19 16V calipers will all bolt straight on no problems. Old ones off, new ones on.....inc the discs.
They DO, give better braking, and performance braking parts are more readily available and cheaper.
Some people report no change in brake pedal travel, whilst i have noted an increase in mine, so i replaced the master cylinder with a 16V item. problem solved. Yours right now might just have a air block in them.
Overall, an easy and worth while mod.
yes...
(this replys is more like IRC eheh)
The only reason I can see why I dont have any more pedal travel is that my car already has a valver master cylinder.
I would not be surprised since it also has got part of valvers interior.
I own a RTi... I dont think you uk ppl got this model. btw, our RSI comes with all valver interios (including the 3 extra oil gauges) and the valver rear 4 torsion bars axle with discs... (some diferences I think).
DOH!!!! lol
