Hi guys , I've broke a spring on my front passenger side of my mk1 ,
Last night I got it up on axle stands and removed both struts , the struts are showing quite bad signs of wear and i have decided to replace both struts and springs at once ,
I've been wanting to lower the front end for a while now, so might as well kill 2 birds with one stone
I'd love some coil overs , but the budget won't allow ( bad times
My questions are:
Can I put lowering strings on new standard struts? Or will it cause them to wear/ or to bottom out ?
Not had a chance to look at any drawings or measurements yet , so thought I'd see if anyone has had any success?
I'm thinking of lowering the front by either 40-50mm
If for example , if it says the the springs lower by 50mm , is that the drop after the springs have settled in?
Or is that the initial drop after fitting and they get lower as the springs bed in?
(I.e 50mm ,after bedding in 60mm??)
Any help would be greatly appreciated
My questions are:
