Quote: Originally posted by 172cup_nut on 16 July 2004
Quote: Originally posted by .Griff. on 16 July 2004
Anyone? Tried to se off the alarm by opening the door using the key and all I get is a high pitch noise but no siren.
hi, theres no beep on locking/unlocking, and i dont think you can set the proper alarm off by opening the door with the key. you do get that high pitched beep though, if you want to set the alarm of wind the window down and lock the car, give it a little while to arm properly and then put your hand through the open window and it should go off, it might even go off without putting your hand in,because of air getting into the car
[Edited by 172cup_nut on 16 July 2004 at 11:46am]
