quick answer needed
Car  Clio 200
mate is up at crail just now in his 182 but the engine management light has just came on.
its showing ----0 on the fault code trick thing with the dials?
mean anything to anyone?
didnt think 0 was an option Stored faults
t = mean an injection fault has been detected for a minimum of 4 seconds
J = means a fault has been noted on the fuel gauge. It must have disconnected for longer than 100 seconds. The resistance from the fuel tank sensor needs to be between 5 and 350 Ohms.
d = means an injection signal fault has been detected
h = means an oil level sensor fault has been detected. Resistance from the sensor should be between 6 and 20 Ohms. Any reading over 20Ohms is an open cicuit anything under 3 is a short circuit.
did you try resetting it and then firing the engine up again to see if tit re-appears?
not my car mate, its my pals whos still running it up and down the strip at crail hes tried resetting it but it is still showing
i thought it may have been the cat?
would agree with that just incase it is something to worry about. hopefully not though
