Quick question... 172 Mk1 Noise on idle
Car  s2000
I had a look at a couple this weekend, what noise do they make on idle.. is sounded like a normal engine, but with a spool type (whissshin) noise.. ?
Is that right?
no that means a pully is worn.... should sound normal....but lumpy idle....the ones that sound like a milkfloat.....they need the bottom pully changing
so.. whats the cost? the danger while driving and what causes this noise (i.e what up with the pully?)
Basically i have seen a car so sell for 4600, how ever it needs the following:
2 rears tyres (soon ish)
front brake pads,
windscreen whipers
Drivers electric window not working. (moter ok, and you can hear the solonied clicking)
A few touch ups on the paint (scrape on rear bumper)
a good valet/clean.
Apart from that it drives good, no knocking.. looks good underneath and in the engine. all the panels (no plastic) are totaly straight and the car is all one colour) its a W with 55k and not had too hard a life. (This is just for the misses to drive about)
So im thinking of offering about 3.8K
Danlp6 said:
its the bottom idler on the auxillary belt, its about £50+vat from renault, and an absolute pain in the arse to change, but mines been fine for 20,000 miles so far.
50 for the pully,, and you have been driving 20K with the noise? and/or did you fix it yourself?
Cheers..
think hes been driving on it like that...? just buy one that doesnt do it if u dont want to carry out the work (unless that one is cheep and mint)
well its not mint, but cheap (if i get it for that price) and quite happy to spend 200-300 getting it up to a1..
just need a little more info abou these pullies please..
kk... basiclaly its a ldler pully which the bearing wears and whines.. its not too bad to leave it but not for long as the bearing will wear away and brake .. letting the aux belt slip off which in 80% will knock the cam belt.....(new engine time)
once the idle pully has been changed then it will be fine..... would wana fit a new aux belt when its changed as it has tio come off any way and there only £15 and it save doining it again
Pete said:
£4600 is not cheap for a ph1, especially with those problems.
im going to offer 3700/3800 .. you think that is about right?
and the cost of the change.. the Renault dealer said about 200. .hmmmm
should buy mine!! 4250 ono
but if u can get that one for 3.8 then yer... but thats 800 from what hes asking
i know.. but the work carried out etc.. i think thats fair.
ok ben.. where are you .. link to pics and info on stuff done, cam belt etc.... can i call you pm me the number etc. where are you..?
and please don't have a big bore on it. :)
i live near Bath.
Mike@Rentech changed my idler bearing over in 10 minutes, the belt wasn't even removed.
The part was around £45 from renualt.
